zabbix_agentd not work with php script on centos
  • hollychen503
    • Jul 2013
    I want to use zabbix to monitor mysql with a php script.
    but no luck the zabbix_agentd always run into timeout.
    I traced the code and found zabbix_agentd just call execl to ask /bin/sh to invoke the command.
    then I try to run the command "/bin/sh -c php -v" in my linux ssh terminal and nothing return!
    I know it's not the zabbix_agentd's fault, but how can I fix it?
    OS: centos 6.3, 64bit + php 5.3.3 cli
    many thanks for your help!
  • vic
    • Jul 2013
    • 58
    Not exactly sure what you are trying to do but if you want zabbix-agentd to run something on the remote machine have you set up sudoer?
