Zabbix Active Checks shows red Zabbix availability icon for host
  • tranquilnet
    • Jul 2013
    I have hosts that are not reachable from the Zabbix server but the hosts can communicate and send data to the Zabbix server.
    I copied the default OS template and mass updated the items to "Agent Active". I added hosts that meet the scenario above to this newly created "Active Agent" template.
    All is working well, however, I see that the Zabbix Agent Availability "Z" icon is red.
    1) Since data is being received by the server from the Zabbix agent, is there a way I can modify a value in the zabbix server so that when the agent is sending data, the Zabbix Availability "Z" icon for the host is green?
    2) Also, if/when data is not being received from the host, I can modify a setting to set the "Z" icon to red?
    Thanks,
    -Will
  • richlv
    • Oct 2005
    • 3112
    you probably still have some passive item there (lld rule ? prototype ? )
    also see https://support.zabbix.com/browse/ZBX-1916
