Hypervisors' monitoring with Zabbix
  • eric_draven
    • May 2013
    • 24
    Hi guys,
    I should monitor some virtual machines under different hypervisors (Xen, KVM and Hyper-V).
    Is there any way to monitor them checking the hypervisor statistics and not the single machines' zabbix agent?
    I mean that I would prefer check the performance of a virtual machine not installing the Zabbix agent on the machine, but using just some functions of the hypervisor (xen, or KVM, or ...).
    Could you help me, please?
    Thank you
  • fjrial
    • Feb 2010
    • 140
    For Xen, there is some work in this thread..
    I managed to get this in production in our systems..
    It´s dirty, but it works..
    See the screenshot with latest data from a Xenserver with several domus running on it.
    For KVM, working on it, I think I can get all info I need using libvirt-snmp...
    Cheers.
    • maxxer
      • Oct 2010
      • 80
      hi. did you share a template for libvirt monitoring? thanks
