mysql: command not found error
  • anoop
    • Jul 2013
    I am new to Zabbix and want to test this tool for my organization. I have followed the instruction manual and installed the rpm package.
    following components have been installed,
    [a400726@vc2c09mmk2651 ~]$ rpm -qa | grep zabbix
    zabbix-2.0.6-1.el6.x86_64
    zabbix-server-mysql-2.0.6-1.el6.x86_64
    zabbix-agent-2.0.6-1.el6.x86_64
    zabbix-server-2.0.6-1.el6.x86_64
    zabbix-web-mysql-2.0.6-1.el6.noarch
    zabbix-release-2.0-1.el6.noarch
    zabbix-web-2.0.6-1.el6.noarch
    The next step as per documentation is,
    Creating initial database
    Create zabbix database and user on MySQL.
    # mysql -uroot
    while i enter the above command i get
    -bash: mysql: command not found error message.
    I am trying to install this on Red Hat Enterprise Linux, 2.6 64 bit version.
    Any help would be really appreciated, i am stuck at this point and not able to proceed further..
    Anoop
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    You need to install MySQL server and client software.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • anoop
      • Jul 2013
      Thanks for responding Alexei,
      Let me know if this is the correct procedure or any additional steps are needed,
      What i tried was, downloaded rpm package using wget
      Step1:- wget http://repo.zabbix.com/zabbix/2.0/rh...el6.noarch.rpm
      Step2:- rpm -ivh <installable>
      Step3:- yum install zabbix-server-mysql zabbix-web-mysql
      I was under the impression that mysql is installed as part of step3, looks like thats not the case. Do you have any specific set of instructions for mysql installation for zabbix?
      • LenR
        • Sep 2009
        • 1011
        Compare to this list, you're probably missing mysql-xxxxx something. The versions may be different, this is from RHEL 5,
        # rpm -qa | grep -i mysql
        mysql-server-5.0.95-5.el5_9
        zabbix-web-mysql-1.8.15-1.el5
        mysql-5.0.95-5.el5_9
        zabbix-server-mysql-1.8.15-1.el5
        mysql-devel-5.0.95-5.el5_9
        php-mysql-5.1.6-40.el5_9
        perl-DBD-MySQL-3.0007-2.el5
        • dirckcopeland
          • Oct 2013
          • 50
          anoop,
          I ran onto the same problem - thinking that mysql was included in the zabbix package but that is not the case. It would be helpful for the installation notes at:
          to make mention of that.
          Never the less, I issued the following command to install the mysql database and client apps.
          yum install mysql-server.x86_64 mysql.x86_64
          then make sure you start the service:
          service mysqld start
          before proceeding with the rest of the instructions at the above link.
          • LenR
            • Sep 2009
            • 1011
            RPM packaging should ensure that something is providing mysql, but just the client part. Zabbix can't know whether your mysql server will be local or not.
