Calculated Items with aggregatges in 1.8
  • blaughton
    • Aug 2013
    Goal: to generate a graph showing the CPU user time used by a group of servers. Taking into account that some servers have more CPU cores than others.
    Method:
    On the servers, created a calculated item call CPUWeightedBusy which is system.cpu.util[,avg1]*system.cpu.num[]. --- works fine, can see value on all individual hosts
    Create a "Calculated item" on a dummy host
    Description: Servers CPU % busy
    Key: Servers.CPU.busy
    Type: Calculated
    Formula:
    last("grpsum[\"Servers\",\CPUWeightedBusy"\",\"last\",\"0\"]")+2
    Note, that this will not be my final formula, this is just the beginning stepping point
    I can save the item properly, but after a minute, the following shows in the log ...
    Item [zabbix-01:Servers.CPU.Busy] is not supported
    Any ideas
