Odd problem with SNMP checks
  • Jason
    • Nov 2007
    • 431
    I've an odd problem with a zabbix proxy and SNMPV3 checks...
    proxy is 2.0.6
    I can do local SNMP checks to a local machine fine.
    However, with a remote machine I'm seeing a lot of
    13248:20130809:133052.732 SNMP item [hrProcessorLoad] on host [remote host] failed: first network error, wait for 15 seconds
    Some of the data comes in eventually, but nothing like as often as it should be.
    If I do a snmpwalk from the proxy to the remote host I get all the data back instantly with no problems so I know the network is ok and that data is flowing both ways ok...
    I thought it could be a timeout somewhere, but if it was that then I thought I would have seen that on the local machine and the snmpwalk wouldn't have worked as well...
    Currently this proxy is only monitoring 2 hosts so I don't think its a resource issue on the proxy and I've plenty of pollers running.
  • Jason
    • Nov 2007
    • 431
    Switched to SNMP V2 and it all seems fine...
    Looks like it is this bug https://support.zabbix.com/browse/ZB...s:all-tabpanel which should be fixed for 2.2
