configuring simple icmpping.
  • bennethos
    • Jan 2005
    • 31
    Hi all,
    total noob question..
    I'm happy I got everything installed, all is working well, frontend and all...
    to give it a try I wanted to do a simple icmpping monitoring of my localhost(where the server is running on)...
    I made a host called localhost, with ip 127.0.0.1, put it in status monitoring.
    I went to items and created an item icmp test, simple check, key : icmpping, update interval 5 seconds...
    It it isn't giving errors in the ERROR column... So I guess its working...
    I made a screen with 1 row and 1 column... I added a graph there for my localhost icmpping to receive it as text...
    it gives me even after couple of hours : 1H history, no data is stored...
    Can anyone help me please ?
    I just want something simple to tests it... If you read this post Alexei, the soft is great, but it lacks a newbie example of how to set up a plain and simple icmpping for the localhost...
    thx for helping me out
  • bennethos
    • Jan 2005
    • 31
    I added a simple check http for my apache with graph fixed value 0 to 1 with a fill up... it works fine !!!
    So it's only the icmp that is giving problems ...
    it still says ICMP Ping 1 hour history NO DATA FOUND FOR THIS PERIOD
    I read something about pinger.pl in the documentation and fping...
    I installed fping and placed it in /usr/local/zabbix/bin
    I adjusted the zabbix_server path for fping, and restarted the server... no go...
    I can't find a pinger.pl file on my server... it's not in the zabbix tar as well.
    any idea's where I could look ?
    I use the latest zabbix, the Zabbix 1.1alpha5
    thx for giving me some hints were to look
    • sauron
      • Jan 2005
      • 215
      you set SUID bit on fping ? If not set it.
      • B_A_C_H
        • Dec 2004
        Originally posted by bennethos
        Hi all,
        Check your history parameter if it is 0 then no data will be inserted to history table, so no chart for your parameter
        For pinging of the hosts I would suggest you to use external Perl script+fping+zabbix_sender
        • bennethos
          • Jan 2005
          • 31
          thx a lot ! It solved my problem... The graphs were allready configged, i did a chmod u+s on the file and suddenly the icmp started to work...
          zabbix rules !
