I recently started having a single system show the check 'proc.num[fhgfs-storage]' has having a value of 0 every other check interval.
On the client, if I run "watch -n 1 'zabbix_agentd -t proc.num[fhgfs-storage]' as the zabbix user, it always returns 1. However in the web interface, every other check interval is showing as 0.
The client is Scientific Linux 6.4 x64 using zabbix20-agent-2.0.6 (from EPEL). The server is CentOS 6.3 x64 using zabbix20-server-mysql-2.0.4 (from EPEL).
Below is the raw plain text from zabbix interface.
I have an identical system (hardware, software, etc) with the same items and it does not have this issue.
What can cause this to occur?
- Trey
# sudo -H -u zabbix sh -c '/usr/sbin/zabbix_agentd -t proc.num[fhgfs-storage]' proc.num[fhgfs-storage][fhgfs-storage] [u|1]
# ps aux | grep fhgfs root 28707 2.1 0.1 1518580 83996 ? SLsl Aug13 23:39 /opt/fhgfs/sbin/fhgfs-storage cfgFile=/etc/fhgfs/fhgfs-storage.conf pidFile=/var/run/fhgfs-storage.pid
Number of fhgfs-storage processes 2013-08-14 12:45:13 1376502313 0 2013-08-14 12:45:11 1376502311 0 2013-08-14 12:44:18 1376502258 1 2013-08-14 12:44:16 1376502256 1 2013-08-14 12:44:13 1376502253 0 2013-08-14 12:44:11 1376502251 0 2013-08-14 12:43:18 1376502198 1 2013-08-14 12:43:16 1376502196 1 2013-08-14 12:43:13 1376502193 0 2013-08-14 12:43:11 1376502191 0 2013-08-14 12:42:17 1376502137 1 2013-08-14 12:42:16 1376502136 1 2013-08-14 12:42:13 1376502133 0 2013-08-14 12:42:11 1376502131 0 2013-08-14 12:41:17 1376502077 1 2013-08-14 12:41:16 1376502076 1 2013-08-14 12:41:14 1376502074 0 2013-08-14 12:41:10 1376502070 0 2013-08-14 12:40:17 1376502017 1 2013-08-14 12:40:16 1376502016 1
- Trey
