Discovery Disks & IO/Performance
  • dvuong
    • Aug 2013
    I found the following articles:
    I'm having problem importing the template.
    Currently running: Zabbix 2.0.6
    Trying to get disk discovery (like filesystem size but for I/O)
    And automatically generate I/O graph for disk ...
    Anyone have such a template to share?
  • cidnurg
    • Aug 2013
    Here you go
    Encountered the same problem today and decided to share solution - https://github.com/grundic/zabbix-disk-performance
    • dkanbier
      • Jul 2013
      • 13
      I've created a template with LLD support for Zabbix 2.2.1:
      I don't have access to a hardware raid device at this very moment, when I do I'll try to add that as well.
      • joshuamcdo
        • Nov 2013
        • 76
        Reisk i/o
        You mean to tell me that zabbix still doesn't support this natively?
        • kloczek
          • Jun 2006
          • 1771
          Creating list of block devices can be done by system.run[] like:
          system.run["awk 'BEGIN {print \"{\"; print \"\\"data\\":[\"; ORS=\"\"} {if (NR!=1) {print \",\n\"}; print \" { \\"{#DISK}\\":\\"\" $3 \"\\" }\"} END {print \"\n ]\n}\n\"}' /proc/diskstats"]
          complicating LLD by use external UserParametr and script usually adds unnecessary level of complexity.
          Filtering off some part of LLD json string can be done natively by using zabbix regexp. With LLD key using system.run[] and regexp done of scripts is needed.
          If you have few hosts to monitor it may be not a problem to use some script executed by agent. However on scale hundredths or thousands hosts it is real nightmare.
          • jan.garaj
            • Jan 2010
            • 506
            Yes, it supports natively, keys: vfs.dev.read, vfs.dev.write *
            You don't have access to all block devices metrics (/proc/diskstats), because IMHO it's problem with different OS and their IOps metric implementation. Some kernel versions (e.g. 2.6.18-53.el5.centos.plus, 2.4-) can be also problem, because they don't provide all "standard" block device metrics.
            For me is important question which monitoring system can provide extended IOps monitoring (avgqu-sz, %util, ...) natively?
            Does someone know answer?
