Action for applying templates to printers
  • oliverm
    • May 2006
    • 155
    Ive got an action that is meant to be assigning my Printer template to any discovered device which has one of several values ("printer", "laser", "inkjet" etc).
    So far, all the printers I've snmp-walked through have the OID .1.3.6.1.2.1.25.3.2.1.3.1 showing the make and/or model which has words such as Laser in the string.
    Given that the OID has the string in it, should my action be working? It isn't you see.
    Does the received value in the action only check certain values or does it walk through all the OIDs?
    Is there a better way to auto associate a discovered SNMP printer with a template?
    Olly
