host/trigger dependencies with zabbix proxy
  • thiago.info
    • Feb 2008
    • 28
    I know that today (2.0.8) Zabbix does not support host dependencies, only trigger dependency. No problem, I just would like some suggestions on how to avoid alerts from the hosts that are monitored through proxy, like "Zabbix agent on HOST is unreachable for 5 minutes".
    Do I need to modify all of my hosts triggers to include a trigger dependency on a trigger that checks my zabbix_proxy availability? If so, is there a way to do it on a bulk way as I have lots of servers?
  • Heilig
    • Mar 2013
    • 366
    I can offer at least 4 options:
    1) create dependencies on the template level
    2) create dependencies manually
    3) create dependencies via API
    4) create dependencies using export/import
    The first option I like more than others (example for 3 proxies):
    1) remove all links for the "Template App Zabbix Agent" with other templates (Template OS AIX, Template OS Linux, etc)
    2) "clone" template "Template App Zabbix Agent" in "Template App Zabbix Agent (Proxy 1)", "Template App Zabbix Agent (Proxy 2)", "Template App Zabbix Agent (Proxy 3)"
    3) creates the template "Template App Zabbix Proxy"
    4) in "Template App Zabbix Proxy", create triggers "Zabbix proxy {HOST.NAME} is unreachable"
    5) create the links between triggers "Zabbix agent on {HOST.NAME} is unreachable for 5 minutes" and "Zabbix proxy {HOST.NAME} is unreachable" (in "Template App Zabbix Agent (Proxy 1-3)" and hosts "Proxy1, Proxy2, Proxy3")
    6) link "Template App Zabbix Agent (Proxy 1-3)" to the necessary hosts
    But in general, all depends on the situation (the number of proxies, the current links, number of hosts, etc).
    • Heilig
      • Mar 2013
      • 366
      Also, you can use the "mass update" feature. Create in the "Template App Zabbix Agent" triggers like "Zabbix agent on {HOST.NAME} is unreachable for 5 minutes Proxy #" (eg, "Zabbix agent on {HOST.NAME} is unreachable for 5 minutes Proxy 1", "Zabbix agent on {HOST.NAME} is unreachable for 5 minutes Proxy 2 ", etc). Create a dependency with triggers "Zabbix proxy {HOST.NAME} is unreachable" (on proxy "host level") and then through the "mass update" disable not necessary items on the hosts (for host that is monitored through proxy1 turn off items "Zabbix agent on {HOST.NAME} is unreachable for 5 minutes Proxy 2 ", etc.).
