Zabbix EventID trigger
  • drakeca
    • Sep 2013
    Total newbie here, but I've been trying to get my way through this.
    I have a backup application which writes Information data to a log file on a Windows server. I want to send an email when a certain EventID is written to the log. So far I have created the following Item:
    eventlog[BACKUPSW,,,,6003,,]
    This works, and I can see data being logged if I check the Latest Data link for that server. I next tried to create a trigger and tried to save the following:
    {BACK-SRVR:eventlog[BACKUPSW].logeventid(6003)}=1
    The system won't allow me to save this and says the Key is incorrect. I tried to use the Expression Constructor and it came up with the following:
    {BACK-SRVR:eventlog[BACKUPSW,,,,6003,,].last(0,60)}=1
    This allows me to save the trigger, but when it collects the data I see an error message, with information "Format error or unsupported operator".
    Any suggestions on how I can get the trigger to kick in?
    Any feedback would be appreciated.
  • steveboyson
    • Jul 2013
    • 582
    Try that one:
    {BACK-SRVR:eventlog[BACKUPSW,,,,6003,,]}.last(0,60)=1
    • drakeca
      • Sep 2013
      Thanks for your quick response. I try to add the trigger, as you quoted, but receive the error message "Incorrect trigger expression. Check expression part starting from "{BACK-SRVR:eventlog[BACKUPSW,,,,6003,,]}.last(0,60)=1".
      It doesn't seem to like me moving the brace within the trigger statement.
      • steveboyson
        • Jul 2013
        • 582
        Hmmm you're right, the curly brackets are enclosing the last... statement.
        Sorry, my fault.
        Maybe something like
        {BACK-SRVR:eventlog[BACKUPSW,,,,6003,,].str("Some Error string:")}#0
        where "Some error string" is in your eventlog text could help.
        • drakeca
          • Sep 2013
          Thanks mate, that seems to have fixed the problem!
