Zabbix Server Running = NO in Dashboard
  • olyanderson
    • Sep 2013
    I can not understand why I have this error in logs:
    19496:20130910:013211.981 Starting Zabbix Server. Zabbix 2.0.8 (revision 38017).
    19496:20130910:013211.982 ****** Enabled features ******
    19496:20130910:013211.982 SNMP monitoring: YES
    19496:20130910:013211.982 IPMI monitoring: YES
    19496:20130910:013211.982 WEB monitoring: YES
    19496:20130910:013211.982 Jabber notifications: YES
    19496:20130910:013211.982 Ez Texting notifications: YES
    19496:20130910:013211.982 ODBC: YES
    19496:20130910:013211.982 SSH2 support: YES
    19496:20130910:013211.982 IPv6 support: YES
    19496:20130910:013211.982 ******************************
    19496:20130910:013211.987 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: NO)
    19496:20130910:013211.988 Database is down. Reconnecting in 10 seconds.
    19496:20130910:013221.988 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: NO)
    19496:20130910:013221.988 Database is down. Reconnecting in 10 seconds.
  • eskytthe
    • May 2011
    • 363
    Seems like you are not using the right password for your zabbix database,.
    You can specify it in your zabbix_server.conf file, and restart the zabbix server.
    BR
    Erik
    • olyanderson
      • Sep 2013
      got it thanks
      i checked all the conf files that applied, found there are duplicates for zabbix_conf.php, in /etc/zabbix and /var/ww/html/zabbix/conf.
      which one i couldnt tell is the right one, but i changed user/pw in both, and it worked.
      1. which one matters? in var or etc?
      2. i now have new issue:
      i selected the https option in the gui. how do i turn it off, in zabbix db? i can not log in, as ssl is not working right, before i turned on https.
      suggestions? thanks.
      • tchjts1
        • May 2008
        • 1605
        zabbix.conf.php resides in /var/www/html/zabbix/conf
