Calculated String items
  • simonquentel
    • Mar 2013
    • 49
    Hi everyone,
    I am using calculated hosts to gather items from several hosts into a unique "virtual host", that I use for maps modling purpose.
    What I am usually doing to "pass" an item from a host to the virtual host is a calculated item, which formula is:
    last("REAL_HOST:ITEM_KEY")
    The problem is that it seems to be doable only when the "real item" is a numeric value.
    Is there a mean to do it with a string?
    To be honest this limitation is a major issue since I can't deploy maps without it.
    Thnak you in advance for your help,
    Simon
  • steveboyson
    • Jul 2013
    • 582
    I'm using expressions like
    {myhost:myItem[param1,param2].last(0)}
    as labels for map elements.
    Works perfectly.
