system.cpu.load works from command line only
  • dtadic
    • Sep 2013
    I am using Zabbix server (Ubuntu 12.04) to monitor Win XP client.
    When I type "zabbix_get -s x.x.x.x -k system.cpu.load" on server command line I receive response from Zabbix agent on Win XP.
    But, when I create new item with key system.cpu.load I receive error "not supported by Zabbix agent".
    Item type is "Zabbix agent"
    Type of infromation "Numeric (float)"
    Problem is the same with key system.cpu.util.
    I have no idea where to search for problem solution.
    Thanks in advance for any help.
  • alisson
    • Nov 2009
    • 70
    Simply change "Type of information" of item to "Numeric (float)", probably it is configured as "Numeric (unsigned)".
    __________________
    Alisson Oliveira
    [url]www.zabbix.com.br[/url]
    [url]www.unirede.net[/url]
    Porto Alegre - RS - Brasil
    • dtadic
      • Sep 2013
      I tried both options, but it does not help.
