{#IFNAME} trigger filter
  • Filter
    Hi, I have a trigger prototype to detect high traffic on network interfaces and it looks like this:
    Name:
    Too much incoming traffic on {#IFNAME} on {HOSTNAME}
    Expression:
    {Template OS Linux:net.if.in[{#IFNAME},bytes].min(5m)}>50M
    I would like to exclude interfaces named like eth1 because they are for backup purposes only.
    Can somebody help me to write and expression for that?
    based on this post Edit vfs.fs.size trigger NOT to go off for disk C: i created following workaround which might help in this case:
    using "Template OS Linux" ("Discovery rules" -> "Network interface discovery")
    "Item prototypes" -> Create item prototype
    Name: Interface echo name {#IFNAME}
    Type: External check
    Key:  echo["{#FSNAME}"]
    Type of information: Text
    "Trigger prototypes" -> Create trigger prototype
    Name: Over 10 MBit/s Incoming Traffic in last 5min on Interface {#IFNAME}
    Expression: {Template OS Linux:net.if.in[{#IFNAME}].last(5m)}>10M and {Template OS Linux:echo["{#IFNAME}"].regexp(^ppp)}=1
    Name: Over 10 MBit/s Outgoing Traffic in last 5min on Interface {#IFNAME}
    Expression: {Template OS Linux:net.if.out[{#IFNAME}].last(5m)}>10M and {Template OS Linux:echo["{#IFNAME}"].regexp(^ppp)}=1
    have in mind that this creates triggers for *every* discovered interface, if you monitor devices with many interfaces, you might want to exclude unneeded interfaces from discovery in Administration->General->Regular expressions->Network interfaces for discovery
    tested on zabbix 3.2.7.
      if you dont like the approach having many items and triggers, see thread Create trigger for interfaces where i posted another approach.
        According to the documentation (Trigger expression), all trigger follow the syntax below:
        {<server>:<key>.<function>(<parameter>)}<operator><constant>
        {#IFNAME} = ppp0 is not allowed.
        Just create an item "ppp0" and a trigger using it, instead of using low-level discovery for this interface.
        Facetime for Android Download (Latest Update)
