Sum of values from discovered snmp items
  • erghezi
    • Oct 2013
    Hi
    how can I graph all network traffic from discovered snmp items?
    I want to monitor all network traffic of hotspot users in a wireless network . when I create a calculated item, everything works well until the the user logs off and when the item becomes available again the sum start from the first.
    thanks
  • Pada
    • Apr 2012
    • 236
    Doesn't there exist a SNMP OID that has the total, so that you don't need to sum all the values in Zabbix?
    Alternatively, write a shell script to sum all the values.
    • erghezi
      • Oct 2013
      no I'm using a mikrotik router and it only has InOctets and OutOctets items for each hotspot user.
      I set zabbix to keep discovered items in history for a year! but how can I force it to sum new values with historical data?
      I can write a script to discover and sum values from snmpwalk but I have no idea how to sum this new values with historical zabbix data
      thank you.
