Zabbix Java Gateway Help
  • tomtomclub
    • Oct 2013
    • 9
    We originally installed Zabbix server on Centos 6 using the rpm from the Zabbix website. Later we realized we needed to install the Java gateway, and found a way of doing it without compiling it using packages put together by Zabbixzone. I ran the install and it seemed to work fine.
    What's happening:
    I add a JMX agent item to a server that is already running and using the Zabbix agent. As soon as I select JMX Agent from the "Type" dropdown the "Select" button on the Key line greys out. I manually input a key. I originally tried "jmx["java.lang:type=Memory","HeapMemoryUsage.used"]" straight from the 2.0 manual, and then tried something simpler (jmx["java.lang:type=Runtime",Uptime]). No matter what, the JMX icon never turns green, and I never receive any info for the host.
    Troubleshooting:
    -I've verified that the Zabbix server is listening on port 10052. I can telnet to port 10052 on that server as well.
    -I've verified that I can get the JMX connections to my clients by using jconsole from my laptop and jmxterm from the Zabbix server itself.
    -I've checked the log for the Java gateway. It says the server started, is listening on port 10052 on all interfaces.
    -I turned on debugging on the Zabbix server in logback.xml and got an additional line (only one) that says:
    2013-10-01 20:08:10.852 [pool-1-thread-1] WARN com.zabbix.gateway.SocketProcessor - error processing request
    java.io.EOFException: null com.zabbix.gateway.BinaryProtocolSpeaker.getReques t(BinaryProtocolSpeaker.java:56) ~[zabbix-java-gateway-2.0.8.jar:na]
    at com.zabbix.gateway.SocketProcessor.run(SocketProce ssor.java:51) ~[zabbix-java-gateway-2.0.8.jar:na]
    at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1146) [na:1.6.0_24]
    -I get nothing in the agent log on the client side.
    Any tips?
  • tomtomclub
    • Oct 2013
    • 9
    Never mind.
    • tiarnaigh
      • Sep 2013
      • 27
      Hi tomtomclub.
      Did you manage to get this working since? If so, can you please post what steps you took to resolve?
      Thanks,
      M
      • fletch
        • Oct 2014
        Hi
        I've got the same problem. What was your solution to fix this bug?
