External Script - no vlaues
  • dorsepp
    • Oct 2013
    • 9
    Hi all,
    I have a problem with my zabbix 2.0.8. I try to use an external python script which give me the values from an ESX-Server via CIM - API. If I execute the script on the zabbix console everything is fine, but when I try to use an item I get no value back. I tryed to fix the problem with changing the "Type of Information" but there was no affect. I changed the debuglevel to 4 but i can´t find the transfered command in the log. The item comes not to "not supported".
    I checked the sytax for the key too. The executable script is named cim.esx and my zabbix-user have access.
    So the key is cmi.esx["parameter"]. The interface is named xxx.xxx.xxx.xxx:10051 but i don´t know the port is transfered and the problem is there.
    So is there a possibilty to see the realy transfered command to fix this problem?
    Do somenone have the same problem with this zabbixversion and annother external script?
    I hope someone can help me and sorry for the bad english.
    Thanks in advance.
    Greetings Sepp
  • steveboyson
    • Jul 2013
    • 582
    It's probably a timeout issue. Querying ESX servers is a pretty time consuming thing.
    I would suggest to redirect output to a text file, schedule this via cron and create an external script which just greps out the relevant information out of this file.
    • dorsepp
      • Oct 2013
      • 9
      Thank you for the quick answer. After few hours I found the reason for the issue.
      I have to insert a second parameter for the script. It´s not cim.esx["parameter"], it´s cim.esx["{HOST.CONN}","parameter"].
      I have done it with an how to from lab4.org. It´s possible the how to works with an older version of zabbix.
      Now everything is fine and with our vSphere Farm with different Hardware it is much easier to monitor. IPMI is a much better way for this reason. It works fast, but with ILO3 there are not enough values.
      Thanks for your help
      • gavind
        • Mar 2013
        • 59
        Thanks for pointing that out. I'll keep that in mind.
