API + trigger.create
  • rawsik
    • Oct 2013
    Hi!
    I try to create new trigger like:
    trg1="Lack of available memory on server {HOST.NAME}"
    exp1="{" + str(template_name) + ":vm.memory.size[available].last(0)}<20M"
    zapi.trigger.create(description=trg1,expression=ex p1)
    It works.
    And I work to define - Severity.
    I tried like:
    exp1="{" + str(template_name) + ":vm.memory.size[available].last(0)}<20M,<Severity>.+</Severity>,100"
    and
    exp1="{" + str(template_name) + ":vm.memory.size[available].last(0)}<20M,Severity='Average'"
    It doesn't work.
    How to create trigger via API with severity ?
  • stok303
    • Apr 2019
    zapi.trigger.create(description=trg1,expression=ex p1,priority=4) will set the severity to high.
