I was wondering if anyone would be able to give me a hand with this. I am new to Linux (mainly been using CentOS) and even newer to SUSE.
I manage to get the agent installed on one of our servers here running SUSE, but it does not seem to be polling the hard drives or space on them. I am not sure if this is a config issue, compatibility issue, or just me being an idiot (very possible).
Is there anything I can do to correct this? I thought it was possibly the way I installed the agent manually, so I removed everything and re-installed using a repository I found in YAST.
See below (no drives polled even after several hours):
Some details of the OS and template:
Thank you.
Thank you.
ort (or hostname
