Proxy 2.0.8 SNMP - All Responses:0
  • avenn
    • Nov 2011
    • 12
    Trying to get SNMP data from remote LAN devices via same site remote zabbix proxy 2.0.8. Connected via open VPN.
    Proxy logs at debug level 4 suggest request gets through however response for a variety of OIDs appears to be just zero:
    get_snmp() snmp_synch_response():0
    When I SNMP walk from the proxy to the SNMP device that value returned is accurate:
    snmpwalk -v2c -c public 192.168.0.2 .1.3.6.1.2.1.2.2.1.16.1
    iso.3.6.1.2.1.2.2.1.16.1 = Counter32: 63053571
    Directions on the forums suggest my setup is accurate?
    Regards
    Aidan
    Proxy log extract:
    29049:20131011:133742.554 In get_value_snmp() key:'ifOutOctects' oid:'.1.3.6.1.2.1.2.2.1.16.1'
    29049:20131011:133742.556 In snmp_open_session()
    29049:20131011:133742.559 End of snmp_open_session()
    29049:20131011:133742.561 In snmp_normalize(oid:.1.3.6.1.2.1.2.2.1.16.1)
    29049:20131011:133742.563 End of snmp_normalize():.1.3.6.1.2.1.2.2.1.16.1
    29049:20131011:133742.564 In get_snmp() oid:'.1.3.6.1.2.1.2.2.1.16.1'
    29049:20131011:133742.576 get_snmp() snmp_synch_response():0
    29049:20131011:133742.578 In snmp_set_value()
    29049:20131011:133742.579 End of snmp_set_value():SUCCEED
    29049:20131011:133742.581 End of get_snmp():SUCCEED
    29049:20131011:133742.582 In snmp_close_session()
    29049:20131011:133742.584 End of snmp_close_session()
    29049:20131011:133742.586 End of get_value_snmp():SUCCEED
    29048:20131011:133743.071 query [txnlev:0] [select hostid,available,error,snmp_available,snmp_error,i pmi_available,ipmi_error,jmx_available,jmx_error from hosts where status in (0,1)]
  • avenn
    • Nov 2011
    • 12
    UPDATE
    upgrade/recompiled to 2.0.9 and attempting to get SNMP data from server - no luck. Using own snmp items and zabbix templates.
    Update net-snmp to latest LTS - no luck.
    Zabbix sender to zabbix is fine - logging great.
    snmpwalk - fine.
    running on deb 7.1
    strange - any ideas?
    Regards
    Aidan
    • avenn
      • Nov 2011
      • 12
      NOT Really SOLVED
      As it was only an experimental server I switched back to ubuntu 12 04 LTS - everything okay now.
      While researching this issue I came across a number of similar issues in relation to debian and zabbix. Probably a fix but could not find and time was ticking on!
