Run a script where there are more active triggers in a host group
  • c.mammoli
    • Feb 2012
    • 48
    Basically I need to open a network relay switch when there are active triggers in a host group. This will trigger an alarm for the surveillance team
    The network relay is controllable via web so is quite easy to open it with a script:
    wget http://relay/relay1=on
    The problem is that I have only 1 relay for an host group, think of this:
    trigger 1 = on -> relay open
    trigger 2 = on -> relay stays open
    trigger 2 = off -> relay closed
    But trigger 1 is still active!
    Obviously I can't use a network relay for every single trigger of the host group!
    I need to find a way to close the relay ONLY when all triggers in the host group are off
    Any idea??
