Dude Trigger
  • anunez
    • Aug 2013
    • 43
    Dude Trigger
    Help please. I have a problem creating a simple check to see di hosts are up and down
    On a Windows host server I get:
    The funny thing is that it is with all my Host ipv4.
    You should enable IPv6 support to use IPv6 family address for SourceIP
  • Pada
    • Apr 2012
    • 236
    Just setup a trigger on the agent.ping item to see if the host is up or down.
    The only times when it should give you an incorrect alert is when the zabbix-agent service is stopped or blocked by a firewall.
    I'm really not sure why you're getting that IPv6 issue. Perhaps you should specify the SourceIP= setting in the Zabbix Server configuration like they've mentioned in this thread: https://www.zabbix.com/forum/showthread.php?t=11799
    Alternatively disable IPv6 on your server and see if that fixes your issue.
