Vertical Hostnames
  • absmith
    • Jul 2006
    Vertical Hostnames
    I have read in the change logs that since 1.1beta9 Hostnames on the overview page should be vertical. I recently installed 1.1 and the hostnames still appear in a horizontal layout. How do I get it to be vertical?
  • erisan500
    • Aug 2005
    • 285
    Did you also updated the frontend ?
    (btw, did you upgraded or clean install?)
    Greetings
    EriSan
    • absmith
      • Jul 2006
      Clean install of both server and frontend. I just discovered Zabbix last week.
      • erisan500
        • Aug 2005
        • 285
        I did a clean install this morning, will check it out.
        Greetings
        EriSan
        • absmith
          • Jul 2006
          Just checking in to see if anyone else has noticed this.
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Check your frontend. It is clearly not from 1.1.
            Alexei Vladishev
            New York | Tokyo | Riga
            My Twitter
            • absmith
              • Jul 2006
              Is there a way I can verify which version I am running? As you can see from this screenshot it says 1.1 and you can see that the hostnames are not vertical.
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                I clearly see that the hostnames are vertical!
                Alexei Vladishev
                My Twitter
                • cameronsto
                  • Oct 2005
                  • 148
                  Vertical = Up and Down (your screenshot)
                  Horizontal = Left and right (like this text)
                  -cameron
                  • absmith
                    • Jul 2006
                    Yeah understand that. But I assumed it ment that the hostnames would be listed verticaly down the left side of the page swaping the triggers and hosts. Since I never used Zabbix before I had no reference to the old style. Anyway I feel pretty dumb now.
                    So now my question is there away to swap the triggers and hosts so I can get the hostnames listed down the page? For me it easier to read down the page than having to scroll to the right.
                    • efeldman
                      • Sep 2006
                      Seconded. I'd also prefer to have the hostnames listed along the left side with the triggers/items along the top (vertically ).
                      Server | Ping | Maximum Cache Buffers | more stuff
                      Srv1 | 5ms | 20000
                      and so on (yes I'm monitoring Netware).
                      I don't like having to crane my neck to see which server I am looking for.....
                      To be honest the output format I am trying to achieve looks like the perl script output you see here (I am using the same script Monash is using to generate data from MRTGEXT.NLM on Netware servers):
                      Any ideas?
                      Eric Feldman
