Dude Maps
  • anunez
    • Aug 2013
    • 43
    Dude Maps
    Help please. I fail to see me the next character on the map (?)
    Input : ↑ {FRDE_E06-0_S001:ifInOctets.10648.last(0)}
    Output : ↓ {FRDE_E06-0_S001:ifOutOctets.10648.last(0)}
    Original
    My Problem:
  • Pada
    • Apr 2012
    • 236
    What version of Zabbix are you using?
    It looks to me like a HTML/image character encoding issue.
    • steveboyson
      • Jul 2013
      • 582
      ↑ = Alt + 24
      ↓ = Alt + 25
      P.S. We use (up) and (down)
      • jan.garaj
        • Jan 2010
        • 506
        Check if you use Zabbix DB (tables, columns) with UTF-8 charset?
        • anunez
          • Aug 2013
          • 43
          as I can verify?
          • jan.garaj
            • Jan 2010
            • 506
            For example use SQL command:
            mysql> SHOW CREATE DATABASE zabbix;
            | Database | Create Database        |
            | zabbix   | CREATE DATABASE `zabbix` /*!40100 DEFAULT CHARACTER SET utf8 COLLATE utf8_bin */ |
            1 row in set (0.00 sec)
