Dude Duplex Switch
  • anunez
    • Aug 2013
    • 43
    Dude Duplex Switch
    Estimated, it is possible in zabbix monitorar duplex ?:
    Values ​​
    1: half
    2: full
    3: disagree
    4: Self
    I have made a: sudo snmpwalk -c public -v2c 192.168.0.4 > /home/XXX/Escritorio/cisco.txt
    and does not show me anything about duplex. The switch is a Cisco 2960
    OID Cisco
  • Pada
    • Apr 2012
    • 236
    If 'sudo snmpwalk -c public -v2c 192.168.0.4 1.3.6.1.4.1.9.5.1.4.1.1.10' returns an integer value in the range 1 - 4, then you can most definitely monitor the duplex in Zabbix.
    • anunez
      • Aug 2013
      • 43
      Thank you very much
      What would be the ID and ID to enter the xml?
      <item type="4" key="memoryUsage" value_type="3">
      <description>Memory usage</description>
      <ipmi_sensor></ipmi_sensor>
      <delay>60</delay>
      <history>7</history>
      <trends>365</trends>
      <status>0</status>
      <data_type>0</data_type>
      <units>b</units>
      <multiplier>0</multiplier>
      <delta>0</delta>
      <formula>0</formula>
      <lastlogsize>0</lastlogsize>
      <logtimefmt></logtimefmt>
      <delay_flex></delay_flex>
      <authtype>0</authtype>
      <username></username>
      <password></password>
      <publickey></publickey>
      <privatekey></privatekey>
      <params></params>
      <trapper_hosts></trapper_hosts>
      <snmp_community>public</snmp_community>
      <snmp_oid>xxxxxxxx</snmp_oid>
      <snmp_port>161</snmp_port>
      <snmpv3_securityname></snmpv3_securityname>
      <snmpv3_securitylevel>0</snmpv3_securitylevel>
      <snmpv3_authpassphrase></snmpv3_authpassphrase>
      <snmpv3_privpassphrase></snmpv3_privpassphrase>
      <valuemapid>0</valuemapid>
      <applications/>
      </item>
      SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10.1.1 = INTEGER: 2
      SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10.1.2 = INTEGER: 2
      SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10.1.3 = INTEGER: 2
      SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10.1.4 = INTEGER: 4
      SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10.1.5 = INTEGER: 4
      SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10.1.6 = INTEGER: 4
      SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10.1.7 = INTEGER: 4
      SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10.1.8 = INTEGER: 4
      SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10.1.9 = INTEGER: 4
      • Pada
        • Apr 2012
        • 236
        Sorry, I meant to say 'snmpget' and not 'snmpwalk'.
        I'm really not sure as to why that value had a tree structure, because according to Cisco SNMP Object Navigator it's supposed to be a value.
        If it does not return a value for that particular OID, then you cannot monitor it OR at the very least you'll first need to find the OID that does return a value. My guess is that the last number in the OID represents the port number.
        The key="memoryUsage" could be changed to like key="portDuplexPort1" and the <snmp_oid>xxxxxxxx</snmp_oid> should be changed to <snmp_oid>1.3.6.1.4.1.9.5.1.4.1.1.10.1.1</snmp_oid>
        • anunez
          • Aug 2013
          • 43
          administrator@ubuntu:~/Escritorio$ sudo snmpwalk -c public -v2c 192.168.0.2 1.3.6.1.4.1.9.5.1.4.1.1.10
          administrator@ubuntu:~/Escritorio$ sudo snmpget -c public -v2c 192.168.0.2 1.3.6.1.4.1.9.5.1.4.1.1.10
          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.10 = No Such Instance currently exists at this OID
          I miss a cisco 2960 does not show that information.
          • Pada
            • Apr 2012
            • 236
            I've updated my previous post...
            If you run snmpwalk, and it returns from .1.1 to .1.24 (or how many ports you have), then you can be assured that the last digits references the port number.
            Like to get port 24's duplex setting, use the OID 1.3.6.1.4.1.9.5.1.4.1.1.10.1.24
            Ideally you should be using discovery rules to detect the amount of ports and to duplicate the monitoring items according to the amount of ports on your switch.
            • anunez
              • Aug 2013
              • 43
              thank you very much, the figures are correct.
              it is normal to only return the number? (not half, dull, disagree and car)
              • anunez
                • Aug 2013
                • 43
                thank you very much
                • Pada
                  • Apr 2012
                  • 236
                  Yes. It's best practice to return integers (or enumerations), because it takes up less space in your monitoring system.
                  In Zabbix you can add a value mapping, by going to Administration > General and then selecting "Value mapping" from the dropdown list.
                  Once you've added the value mapping, you can change your SNMP item's "Show value" setting to make use of the value mapping, so that when you're in Latest Data view, that it will show you the understandable/text representation
                  • anunez
                    • Aug 2013
                    • 43
                    Thank you very much for your help
                    You are well
                    • anunez
                      • Aug 2013
                      • 43
                      I have a doubt with the port speed 10/100 values ​​do not match.
                      Know any oid.
                      • Pada
                        • Apr 2012
                        • 236
                        Please post your snmpwalk results for that portAdminSpeed OID: 1.3.6.1.4.1.9.5.1.4.1.1.9
                        If it returns INTEGER = 100000000, then Zabbix would interpret it as 100 Mbps if you specify the unit as "bps"
                        • anunez
                          • Aug 2013
                          • 43
                          administrator@ubuntu:~/Escritorio$ sudo snmpwalk -c public -v2c 192.168.0.2 1.3.6.1.4.1.9.5.1.4.1.1.9
                          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.9.1.1 = INTEGER: 1
                          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.9.1.2 = INTEGER: 100000000
                          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.9.1.3 = INTEGER: 100000000
                          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.9.1.4 = INTEGER: 1
                          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.9.1.5 = INTEGER: 1
                          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.9.1.6 = INTEGER: 1
                          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.9.1.7 = INTEGER: 1
                          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.9.1.8 = INTEGER: 1
                          SNMPv2-SMI-v1::enterprises.9.5.1.4.1.1.9.1.9 = INTEGER: 1
                          • Pada
                            • Apr 2012
                            • 236
                            I forgot to tell you, but Zabbix already has a bunch of templates, including one for your CISCO switch here: https://www.zabbix.com/wiki/templates/start
                            Please just take note that their SNMP OID suffixes may be slightly different.
                            Unfortunately that template is just for the CPU, Memory and Bytes In+Out and not for the Duplex/Port Speed.
