Need help with SNMP trap config
  • natalia
    • Apr 2013
    • 159
    I need help with SNMP trap config ...
    Traps are sending from app java code to localhost.
    ~200 different traps can be sent and with 2 statuses : ERROR (in case of problem and OK when the problem solved)
    There is no mib.
    How to config forward/resend trap to zabbix server ?
    What should be define in item/trigger in order that each kind of trap apperied in dashboard as separate alert ? and "OK" trap will be ack. "ERROR" from the same type. ?
    Thanks for the help!
