Error connecting to database
  • Dianamx
    • Jul 2006
    I just installed zabbix in Mandrake 9.2. Everything went ok, but when i try to access the main page, i'm getting the following error:
    Error connecting to database [Access denied for user: '@localhost' to database 'zabbix']
    I edited the config_server.conf file and changed the database user and database host.
    Any idea of what is happening?
    Thx
    Dianamx
  • erisan500
    • Aug 2005
    • 285
    If you had to make changes to the zabbix_server.conf file to access the database, i bet you need to do so also for the frontend (includes/db.inc.php)
    Greetings
    EriSan
    • grabber
      • Mar 2005
      • 85
      Thx
      Dianamx
      did you secure the initial accounts in mysql? Make sure your user can attach from localhost.
      Ian
      • Dianamx
        • Jul 2006
        Greetings
        Yes, that was the problem. I made changes to the include/db.inc.php and it's working.
        Thanks a lot
        Dianamx
        • Dianamx
          • Jul 2006
          Ian
          Yes, i did.
          The problem was that i haven't changed the db.inc.php file, but i already did it and it's working now.
          Thank you!
          Dianamx
          • wilfrik2003
            • Dec 2010
            Database error: Error connecting to database
            I have this page pop up when i installed zabbix 2.2.1 and i have added my database password in zabbix_server.conf but its not showing.
            How can i edit the db.inc.php to correct this problem.
            thank you for helping me out here
