MACRO inside a MACRO
  • pinarella
    • May 2013
    • 16
    Hello, i am trying to have a customized trigger names with macros.
    example:
    Host xyz is Down
    Host xyz is Up
    where macro: {$STATUS_NETWORK0} = Down
    and in trigger description name is:
    Host {HOSTNAME} is {$STATUS_NETWORK{ITEM.VALUE1}}
    and trigger is fired and it displays it like this:
    Host xyz is {$STATUS_NETWORK0}
    is it posible to use macros in macros or there is a workaround?
  • pinarella
    • May 2013
    • 16
    Any help? Guides?
    Can i call this dynamic macros?
    • m_gularte
      • Jul 2012
      • 85
      Hi
      Do you really need that?
      What value your item returns? Is it always 1 or 0? If so, you can use value mapping (in adminstration / value mapping):
      Service state
      0 ⇒ Down
      1 ⇒ Up
      And use macro: {ITEM.LASTVALUE}
      Host xyz is {ITEM.LASTVALUE}
      • pinarella
        • May 2013
        • 16
        Oh yes, that solves my problem. i have found similar but didn't know that acts like that in trigger names.
        Thanks!
