Web Check Question
  • jasonw
    • Oct 2013
    • 25
    Web Check Question
    We are trying to do a web check that requires a parameter to be sniffed off the page... So, it looks something like this...
    1) http//gotomyloginpage --> Redirects you to http//real_login_page
    If you did a "view source" on http://real_login_page, you will see that while redirecting, it embedded a hidden field called "request_id" with some randomly generated value like "234982338774"...
    2) In order to complete the login process it then submits something like this:
    http//authenticate_url?req_id=234982338774&username=user &password=myPassword
    So, I need to do something like this:
    1) Hit landing page and wait for re-direct to happen
    2) Parse out request_id from the login page
    3) Pass request_id as part of the POST data.
    Can Zabbix do this? Can it let me parse out something on the page in step 1 to send along with the POST operation in step 2?
