I am new to Zabbix and have a problem with the following: I have created an item that uses a user macro. I would like to use the same item with multiple values. For example I want to check some cluster volumes for free space. The item is always the same, but the path to the volumes differs. I have also tried to add the same macro multiple times, but this isn't allowed.
How can I have one item and use it with multiple parameters/macro values?
Thank you for your help,
Andreas
Andreas
