Exchange DB trigger
  • Magician
    • Mar 2013
    • 11
    Exchange DB trigger
    Hi , i have exchange 2010 dag (cloud environment) i want the zabbix to report when one of the DBS are down i have 25 dbs i need to monitor that i get alert when DB is dismounted .
    i have exchange template - but it doesnt seem like it autodiscovers the DB
    any recommendation how to processed ?
  • steveboyson
    • Jul 2013
    • 582
    1) define the "normal" state
    2) define the "alert" state
    3) what has changed?
    4) create a script which checks that difference
    5) Hook in that script into a "UserParameter" key in your zabbix_agentd config file
    6) restart zabbix_agentd
    7) create an item on the host to be monitored which calls that script
    8) create a trigger for that item
    9) DONE.
    • Magician
      • Mar 2013
      • 11
      ok did it , here is what i did (maybe will help others)
      i've created a script(a ps1 script) that updaing a log file everytime it runs .
      if there is a problem , its writing the databases that are down in that file , and by that it makes the log file more than 0 bytes .
      if no problem it erase everything on the log file and the log becomes 0
      now , ive created additional script vbscript that query the log folder for size .
      than created an item and trigger than if anything is bigger than 0 it will active the trigger .
      the db script will run now with task schedualer and in the future ill transform it into zabbix agent probably .
      this is the phase 1 of masterplan
      next phases of the plan i intend to create folders to each db and create triggers for each db if error or not (dont know how to create a discovery so ill do it manual)
      afterwards ill do something similar with querying the mpoints of each db for free % on that volume .
      anyway thanks for the help .
      • steveboyson
        • Jul 2013
        • 582
        You could write a script which autodiscovers your databases (giving you for example the name).
        Then create item prototypes for each discovered databases which check for status or health, size etc.
        • Magician
          • Mar 2013
          • 11
          yes but it take time now i need to get an sms when db is down (doesnt matter which db is down) to fix it in no time
          nevermind fixed it , had problem in the script as currentlocation was in system32 and not in the directory the other script was
