I have a Zabbix Agent active check item in a Host group which has other templates in it. I made another Active agent check for a specific host under a new template. When i turn the agent on, an active check not associated to the template is ddoing check on the host, but the file structure of that check does not exist on that host?
i have removed the what i thought is a conflicting template from the host group, but it still makes a request on the host for a file structure that does not exist?
Are agent checks template specific? Maybe I have to isolate a little better?
Your help is appreciated.
