Force housekeeper on hudge DB
  • thomas.dub
    • Nov 2013
    In first, sorry for my english
    I'm using Zabbix 2.0.8 for my production monitoring, and I've some items who are checked (more than 40.000 items).
    I want to keep a lot of items, and more trends.
    My server have two SSD for mysql, using InnoDB, but the table « history » it a bit hudge (more than 1.500.000.000 values, for approx. 140GB volume).
    I've setted a small value for item retention, and configured the Housekeeper to remove all values every hours (setting MaxHousekeeperDelete=0 in zabbix_server.conf) but items are deleted too slowly.
    For example, I've had an item with 1 year retention and 3 years trends, for approx. 1.700.000 values in history table.
    I've changed the retention to 60 days and trends to 3 years, but there's still items from the last year in the table, after 1 week.
    I can remove them with a script, but in fact, the last item history is older than the last trend, so if I remove items, I will lost data.
    I think that trends are calculated by the housekeeper, and this one have an hardcoded max value to delete.
    There's no huge load on the database.
    So, I want to start manually housekeeper for deleting more items in one hour.
    Did you have a solution for that ?
    Some infos :
    grep delet zabbix_server.log
    11401:20131108:070312.717 housekeeper deleted: 597187 records from history and trends, 0 records of deleted items, 62 events, 0 alerts, 0 sessions
    11401:20131108:080347.964 housekeeper deleted: 597715 records from history and trends, 0 records of deleted items, 60 events, 0 alerts, 0 sessions
    11401:20131108:090422.270 housekeeper deleted: 597412 records from history and trends, 0 records of deleted items, 60 events, 0 alerts, 0 sessions
    11401:20131108:100457.740 housekeeper deleted: 597166 records from history and trends, 0 records of deleted items, 62 events, 0 alerts, 0 sessions
    Thanks for your help !
  • bbrendon
    • Sep 2005
    • 873
    Probably late, but in case anyone else is looking. Upgrade and run.
    zabbix_server -c /usr/local/etc/zabbix_server.conf -R housekeeper_execute
    See: https://www.zabbix.com/documentation...oncepts/server
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • tritsako
      • Dec 2014
      • 46
      Hi Thomas,
      you can try also the below from mysqlone by one, AFTER you make a backup of you Database:
      1 -- intervals in days
      2 SET @history_interval = "Your History Interval in days";
      3 SET @trends_interval = "the number of days you want to keep";
      5 DELETE FROM alerts WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
      6 DELETE FROM acknowledges WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
      7 DELETE FROM events WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
      9 DELETE FROM history WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
      10 DELETE FROM history_uint WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
      11 DELETE FROM history_str WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
      12 DELETE FROM history_text WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
      13 DELETE FROM history_log WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
      15 DELETE FROM trends WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@trends_interval * 24 * 60 * 60);
      16 DELETE FROM trends_uint WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@trends_interval * 24 * 60 * 60);
      Costas
