Hi guys: This is my first post!!
I had configure zabbix with this parameters
After that I change my zabbix_server.conf enabling the following parameters
Then, I'd started startup.sh on /zabbix/sbin/zabbix_java/ and check in ps ax with tihs result:
And when I try to reload the zabbix_server.conf I receive this message:
zabbix_server [30081]: unknown parameter [JavaGateway] in config file [/zabbix/zabbix_server.conf], line 194
What is the problem??
Thanks in advance
./configure --prefix=/zabbix --enable-server --enable-agent --with-postgresql --with-net-snmp --with-libcurl --enable-java --datadir=/zabbix --sysconfdir=/zabbix
Configuration:
Detected OS: linux-gnu
Install path: /zabbix
Compilation arch: linux
Compiler: gcc
Compiler flags: -g -O2 -I/usr/include -I/usr/include/rpm -I/usr/local/include -I/usr/include/gdbm -I/usr/lib64/perl5/5.8.8/x86_64-linux-thread-multi/CORE -I. -I/usr/include/net-snmp
Enable server: yes
Server details:
With database: PostgreSQL
WEB Monitoring via: cURL
Native Jabber: no
SNMP: net-snmp
IPMI: no
SSH: no
ODBC: no
Linker flags: -rdynamic -L/usr/lib64 -L/usr/kerberos/lib64 -L/usr/lib64 -L/usr/lib64 -L/usr/lib64/lib -L/usr/lib64 -L/usr/lib64 -L/usr/lib64/lib
Libraries: -lm -lrt -lresolv -lpq -lcurl -ldl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lidn -lssl -lcrypto -lz -lnetsnmp -lcrypto -lm -lwrap -lcrypto -lnetsnmp -lcrypto -lm -lwrap -lcrypto
Enable proxy: no
Enable agent: yes
Agent details:
Linker flags: -rdynamic -L/usr/kerberos/lib64
Libraries: -lm -lrt -lresolv -lcurl -ldl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lidn -lssl -lcrypto -lz
Enable Java gateway: yes
Java gateway details:
Java compiler: javac
Java archiver: jar
LDAP support: no
IPv6 support: no
* Now run 'make install' *
* Thank you for using Zabbix! *
* <http://www.zabbix.com> *
JavaGateway=10.250.0.36 JavaGatewayPort=10052 StartJavaPollers=5
java -server -classpath lib:lib/logback-classic-0.9.27.jar:lib/logback-core-0.9.27.jar:lib/org-json-2010-12-28.jar:lib/slf4j-api-1.6.1.jar:bin/zabbix-java-gateway-2.0.9.jar -Dzabbix.pidFile=/tmp/zabbix_java.pid -Dzabbix.listenPort=10052 com.zabbix.gateway.JavaGateway
Thanks in advance
