Cetrificat check
  • Dave_sutfene
    • Nov 2013
    Cetrificat check
    Hello all,
    i am a newbe at zabbix (v2.0.8). and read already many items for checking the expiring date of a certificate.
    i made the folowing script "email.sh" on the server:
    ssl-cert-check -s email.sutfene.nl -p 443 -n | sed 's/ */ /g' | cut -f2 -d=
    it is placed in /var/lib/zabbix/bin and user zabbix can run it. it returns a value let's say 500 which is in days.
    it is based on the post of Alixen https://www.zabbix.com/forum/showthread.php?t=15694
    in zabbix frontend i made an item based on a host??? as attached
    but it doesnt display any results. What am i doing wrong.
  • man
    • Feb 2009
    check this links:
    Join the friendly and open Zabbix community on our forums and social media platforms.
    • Dave_sutfene
      • Nov 2013
      installed it, but ill get the error:
      "items.error: Received value [] is not suitable for value type [Numeric (float)]"
      When i run the script (which is in /var/lib/zabbix/bin) on the server as user zabbix with the parameters i get the correct values.
      i think it could be 2 things.
      1. Zabbix can somehow not run the program, or receive the value.
      --> so i gave zext.... a chmod +x and set zabbix as owner, but it didnt solve it
      2. I did not create a correct item
      --> i created an item with a DNS name of the server put in as SNMP and as agent. see attached image
      i am using zabbix 2.0.8
      • man
        • Feb 2009
        from link in previous post:
        zext_ssl_cert.sh must be installed in Zabbix external scripts directory (/etc/zabbix/externalscripts by default).
        in zabbix_server.conf you can configure location of external scripts. put there zext_ssl_cert.sh and give executable permissions for user who runs zabbix-server
        you can remove snmp interface from host configuration it's not needed.
        certificate check is not SNMP trap type, it's an external check type and key is
        zext_ssl_cert.sh[{HOST.CONN},{$SSL_PORT}]
        with this key zabbix-server will check certificate on that host where you have linked your template
        • Dave_sutfene
          • Nov 2013
          okey, did a new clean installation of zabbix 2.2.0 on ubuntu this time
          but i still get the error
          " Received value [] is not suitable for value type [Numeric (float)]"
          as mentioned zabbix is owner of the file, in the terminal shell the zext can be run and gives a "530" as value.
          i recreated an item with the hostname as DNS in the agent field with port "443"
