Short circuit evaluation for trigger expressions?
  • azabbixuser
    • Nov 2012
    I am trying to find out if Zabbix does short circuit evaluation with trigger expressions, particularly for the logical & operator.
    I've tried the search function for the forum.
    The Zabbix 1.8 book doesn't state it either.
    I've tried Google and the closest I can find is this link.
    Is the author saying that now it does do short circuit evaluation?
    I don't quite understand.
  • azabbixuser
    • Nov 2012
    I answered my own question: it does do short circuit evaluation.
    I looked at the source code, particularly the function "evaluate_simple" in the file src/libs/zbxserver/expression.c.
    A code snippet reveals this:
    case '&':
    	*result = (SUCCEED != cmp_double(value1, 0) && SUCCEED != cmp_double(value2, 0));
    	break;
    There is no compiler directive present that turns off short circuit evaluation. So, however C does it, is the way Zabbix does it. Case closed.
