looking for Icons
  • pey
    • Feb 2005
    looking for Icons
    Looking for Icons ....
    I'm try to configure a map with icons but i just see a a black object on my map.
    When i'm checking mysql database, i can see the image table but this table is empty. is it normal ?
    Zabbix--> 1.1alpha4
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    No, it's not normal! Load images.sql into your database. Before doing this, make sure that all load_file() statements have correct full-path image names in this file.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • elings
      • Mar 2005
      • 16
      Image problem
      Hello !
      I have the same problem and tried to add the images.sql to mysql by
      doing this:
      cat ./images.sql |mysql zabbix
      But i get the following error:
      ERROR 13 at line 24: Can't get stat of/home/zabbix/zabbix/create/data/images/Hub.png' (Errcode: 13)
      Does anyone have any suggestion ?
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Make sure that the PNG files are accessible (have read permissions) by user 'mysql'!
        Alexei Vladishev
        My Twitter
        • elings
          • Mar 2005
          • 16
          That solved my problem...
          Thank you Alexei !
          • omenix
            • Dec 2005
            • 14
            I still dont get this part.. What should I do?
            • omenix
              • Dec 2005
              • 14
              This is my current config
              insert into images values(1,1,"Hub",load_file("/root/zabbix-1.1beta2/create/data/images/Hub.png"));
              insert into images values(2,1,"Hub (small)",load_file("/root/zabbix-1.1beta2/create/data/images/Hub_small.png"));
              insert into images values(3,1,"Network",load_file("/root/zabbix-1.1beta2/create/data/images/Network.png"));
              And this is my file perm:
              But I still get the error message
              • cameronsto
                • Oct 2005
                • 148
                There are a couple things to try:
                1. Make sure that you have modified the contents of images.sql to include the absolute path to the images.
                2. Make sure MySQL has permission to access the images. (chmod ugo+rx <images>)
                3. You might need to move the images to /tmp in order for MySQL to get proper access. Don't forget to modify images.sql again.
                -cameron
                • omenix
                  • Dec 2005
                  • 14
                  Thank you it works fine now. But now I got blank page and theres no error log appear..
