i use zabbix active agent monitor sql2008 error log
key=log["C:\Program Files\Microsoft SQL Server\MSSQL10.MSSQLSERVER\MSSQL\Log\ERRORLOG.6"]
i can't collect any information
i use Notepad++ to open log file ERRORLOG.6,the encoding is UCS-2 little endian
when i use Notepad++ change the encoding to UTF-8,zabbix conlect log information normal
but SQL can't change the error log encoding
i use key=key=log["C:\Program Files\Microsoft SQL Server\MSSQL10.MSSQLSERVER\MSSQL\Log\ERRORLOG.6",, "UCS-2"]
what is the problem?
