2.0.9 -> 2.2
  • LenR
    • Sep 2009
    • 1011
    2.0.9 -> 2.2
    I'm getting these messages in the log after conversion, several every few minutes.
    [Z3005] query failed: [1054] Unknown column 'type' in 'field list' [select type from applications where applicationid=1101100000000001]
    The don't seem to be causing any problems.
  • aink999
    • Jul 2011
    • 11
    Same for me
    Hi same for me I've upgraded from 2.0.2 to 2.2.1
    1 657:20140113:141541.193 [Z3005] query failed: [1054] Unknown column 'type' in 'field list' [select type from applications where applicationid=200200000000822]
    1 657:20140113:141541.193 [Z3005] query failed: [1054] Unknown column 'type' in 'field list' [select type from applications where applicationid=200200000000823]
    1 657:20140113:141541.193 [Z3005] query failed: [1054] Unknown column 'type' in 'field list' [select type from applications where applicationid=200200000000824]
    1 657:20140113:141541.193 [Z3005] query failed: [1054] Unknown column 'type' in 'field list' [select type from applications where applicationid=200200000000825]
    1 657:20140113:141541.193 [Z3005] query failed: [1054] Unknown column 'type' in 'field list' [select type from applications where applicationid=200200000000826]
    1 657:20140113:141541.193 [Z3005] query failed: [1054] Unknown column 'type' in 'field list' [select type from applications where applicationid=200200000000827]
    From what I can see there really no column called type
    mysql> describe applications;
    | Field | Type | Null | Key | Default | Extra |
    | applicationid | bigint(20) unsigned | NO | PRI | NULL | |
    | hostid | bigint(20) unsigned | NO | MUL | NULL | |
    | name | varchar(255) | NO | | | |
    3 rows in set (0.00 sec)
    mysql> select type from applications ;
    ERROR 1054 (42S22): Unknown column 'type' in 'field list'
    mysql> select name from applications ;
    | name |
    | CPU |
    | Filesystems |
    | General |
    | Memory |
    | Network interfaces |
    | OS |
    | Performance |
    | Processes |
    | Security |
    • aink999
      • Jul 2011
      • 11
      Bug report
      I've post a bug report https://support.zabbix.com/browse/ZBX-7644
      we will see.
