Overview like Observium
  • uid0
    • Aug 2013
    today i found Observium which has a really nice dashboard.
    observium. org/wiki/Screenshots
    Especially this is very interessting:
    observium. org/wiki/File:W6dcpbsua4.png
    observium. org/wiki/File:Zlq0ms427g.png
    observium. org/wiki/File:K24c5hs318.png
    It would be really cool if zabbix could have such a good overview. Is there a alternative template which show all network stats of the servers on one page?
    This would be cool because i am already tiered of checking every single server and search the network stat in a big list. With such a page it would be a real tatical overview of all devices and admins have a real overview of their usage of 95% etc.
    What do you think?
  • ArtemK
    • May 2013
    • 232
    why not to use screens/slide shows, which are supported out of the box?
    • uid0
      • Aug 2013
      Yes, that would be an idea.
      But when i select 'Data Overview' in the Screen config, i cant select custom columns.
      With all columns it get extremly confused. If i could select the column which should get shown (example: Load, CPU Usage, RAM, HDD and second screen with network infos) it would be a solution.
      Is there such a option?
