not sure why my text log monitor is going not supported
  • gregtompkins
    • Sep 2011
    • 23
    Hi All,
    I have created a text file monitoring job to watch my syslog for drops from the firewall. I checked the log file and it keeps going not supported and I'm not sure why:
    Here's the entry from the zabbix_server.log
    [root@sentinel zabbix]# more zabbix_server.log | grep messages
      2095:20131122:215515.274 send_list_of_active_checks_json() Item 'log["/var/log/messages","WAN_LOCAL-default-D","UTF-8",100]' was suc                       cessfully found in the server cache. Sending.
      2095:20131122:215515.274 In substitute_key_macros() data:'log["/var/log/messages","WAN_LOCAL-default-D","UTF-8",100]'
      2095:20131122:215515.274 End of substitute_key_macros():SUCCEED data:'log["/var/log/messages","WAN_LOCAL-default-D","UTF-8",100]'
                            "key":"log[\"\/var\/log\/messages\",\"WAN_LOCAL-default-D\",\"UTF-8\",100]",
      2142:20131122:215520.580 item [Zabbix server:log["/var/log/messages","WAN_LOCAL-default-D","UTF-8",100]] became not supported: ZBX_N                       OTSUPPORTED
    Here is how I created the key:
    And here is a line from the file /var/log/messages I want to capture:
    Nov 22 22:00:13 router kernel: [WAN_LOCAL-default-D]IN=eth0 OUT= MAC=XXXXXXXXXXXXXXXXXXXXXXXXXXXX SRC=11.22.33.44DST=99.88.77.66LEN=40 TOS=0x00 PREC=0x00 TTL=87 ID=0 DF PROTO=TCP SPT=443 DPT=51825 WINDOW=0 RES=0x00 RST URGP=0
    Is it that I did the date format incorrectly?
    MMMpddphh:mm:ss ?
    Thanks.
  • gregtompkins
    • Sep 2011
    • 23
    I figured out the problem was because I hadn't given the user 'zabbix' rights to the directory of the files.
