Hello dear friends!
Unfortunately detailed documentation on AIX zabbix server not found.
There are two node AIX versions 6.1 , united in a cluster PowerHA. Task - to monitor logs cluster PowerHA. Zabbix server version - 2.2.0 . I have not found a newer version of zabbix agent for AIX, it was decided to install the agent - 1.6.2 of the rpm package.
1st question:
How to remove the old version of the agent , and to upgrade to newer versions of the agent on AIX servers ( and whether upgrades agent after all monitoring functions are available ) ?
In a standard template zabbix AIX unfortunately no support for monitoring
PowerHA cluster ring logs for the agent version 1.6.2 .
2nd question:
Tell whether it is possible to monitor log files cluster PowerHA AIX?
Thank you in advance !
1st question:
2nd question:
