How to config "Database Monitor" for query returns more than one line/value ?
query return the result in the following format :
object | value
a | possible value : 0,1,2,3
b | possible value : 0,1,2,3
c | possible value : 0,1,2,3
In case of value 1 - alert in severity "Warning", 2 - "Average", 3 - "High", 0 - "OK"
for each object name - should be created separate alert.
Number of objects and exactly which objects I don't know - it change dynamically
Is it possible to implement in Zabbix 2.0 or 2.2 ?
object | value
