Network discovery and UserParameters won't be functional after upgrade to CentOS 6.5
  • davitzen
    • Dec 2013
    Hello!
    Yesterday, I upgraded five of our CentOS systems from 6.4 to 6.5.
    After the upgrade the network discovery rules are not working.
    Zabbix webinterface shows: not supported ???
    BUT: Two of our systems are working fine???
    output on (not working) systems:
    /usr/sbin/zabbix_agentd -t net.if.discovery
    net.if.discovery [s|{
    "data":[
    "{#IFNAME}":"lo"},
    "{#IFNAME}":"eth0"}]}]
    It should be functional, but no data is comming in...
    There were also an upgrade from zabbix agent 2.06 to 2.09, we use Zabbix Server 2.2 on a mysql backend.
    Further I use a UserParameter, which is not working anymore...
    I check status of 3 services with following parameter:
    ps ax | grep -w psaintsvc | grep -v grep | wc -l
    Zabbix Logfile:
    12241:20131202:182216.759 Run remote command [ps ax | grep -w psaintsvc | grep -v grep | wc -l] Result [1] [0]...
    12241:20131202:182216.759 Sending back [0]
    If I check these on console, there ist the correct value.
    Please help me...
    Best regards
    David
  • sq4ind
    • Dec 2013
    Hello David,
    I came across the same problem. But I found the solution: disable selinux, or upgrate its policies.
    Hope it will be helpful.
