proc.num with several processus
  • SLMitch
    • May 2006
    • 39
    I want monitore on my servers if processus apache is running.
    However, le name of processus depend of version of OS, distrib, version of apache..., and i have : apache/apache2/httpd.
    Without using 3 differents items, is it possible to make a "super" items where the result is sum of result we would have with the different keys ?
    Example :
    proc.num[apache]+proc.num[httpd]....
  • pilot
    • Jun 2006
    You can use operators in triggers.
    I think that monitoring of all parameters is right solution.
    Really (in my practice) if all triggers/actions configured well monitoring graphs is not necessarily.
    • SLMitch
      • May 2006
      • 39
      yes.
      As i have several other use cases, i will develop un new key in C...
