monitoring syslog server
  • anishkmr0071
    • Mar 2018
    • 10
    hi everyone,
    can anyone help me to monitor a syslog server. i want to see the logs of my asa.
  • LenR
    • Sep 2009
    • 1011
    I think it would be a 2 step process, you would need a log file on the syslog server with the data from the ASA. We had a syslog server that created a directory for each IP and daily log files. The server will need the zabbix agent or a file share to a zabbix agent. Then a standard zabbix log or logrt item should work, at least to get the data.
    • anishkmr0071
      • Mar 2018
      • 10
      thank you LenR
      • LenR
        • Sep 2009
        • 1011
        Logstash can also send to zabbix: https://www.elastic.co/guide/en/logs...ts-zabbix.html
