Hello Zabbix forum,
I would like to see if I could use zabbix to pull in an XML from my electric monitor and make graphs and do triggers if a certain condition happens. Attached is what the XML output looks like from my system if I go to my TED5000 URL http://10.10.70.23/history/secondhistory.xml
I think what I would do is either use curl or wget and then parse it into zabbix. I'm not that good with scripting though. So any ideas if or how I could pull this off?
I wish I was a company and could afford a support plan but I'm just learning right now.
Thanks!
Thanks!
