Administration scripts in templates
  • boniface
    • Dec 2013
    Hello everyone,
    I'm looking for a way to put scripts into templates. According to the documentation it does not seem as to be possible, but I'm gonna have a bunch of scripts and find it really annoying to enter them manually on multiple instances.
    Maybe the template is not the right thing to do so and there are some other approaches - using API or something like that.
    I'll appreciate any advice.
    Thanks in advance.
